700r4 power handling
Old Nov 15, 2007 | 04:06 PM
dc_sniper9130's Avatar
Car: '84 Camaro SC
Engine: Swapping in a 305
Transmission: 700-R4
Axle/Gears: 3.23 One-Wheel Sqealer
Will an 85 stock 700r4 handle an engine in the neighborhood of 300-350 horsepower?
Old Nov 15, 2007 | 06:07 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 700r4 power handling
You really should look for an 87 to 93 transmission if you're replacing yours. The internal updates make them a bit more reliable.
You will need a companion torque converter as well. Yours uses a 27 spline piece like a 200 and the newer models have 31 spline input shafts.
Old Nov 15, 2007 | 11:07 PM
Car: '84 Camaro SC
Yeah, I've been hearing that the newer ones are better trannys. Will they be able to deal with that amount of torque okay though or will i need to put a kit in it?
I'm also not so much replacing it as making sure it will work. i pulled this motor and tranny out of the same car, and before i finish dumping a couple thousand dollars into the build on the motor, i want to make sure i'm not going to blow the tranny up right away.
Old Nov 16, 2007 | 01:35 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
The original 700r4s like yours are not good behind fresh engines, especially when it is probably well used to begin with.
Now is the time to upgrade. I wouldn't even rebuild yours; there are too many upgraded parts in the newer ones. Sell yours on ebay if it works and go to the junkyard to get a newer one and have it rebuilt. Or, you could use yours as a core charge for a good aftermarket HD transmission. Ebay and the internet are full of those.
stalkier
Dec 6, 2015 11:25 PM
sailtexas186548
Aug 24, 2015 10:11 PM
g.l.mos
Aug 22, 2015 12:02 AM
sreZ28
Aug 14, 2015 07:48 PM
