which differential?
Car: 86' Z28
Engine: 5.0l w/ new cam
Transmission: TH-350
Axle/Gears: 4.10's
which differential?
I have a 1986 camaro sports coupe and i need to get a new differntial, the standard open diff is killing me. i was thinking about a spool because it is cheap and easy, but ive heard the can break axels. does anyone now whare or how i could get a lsd or spool for the 7.5 or 7.625 rear ends?
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: witch differential?
summitracing.com, and don't get a spool. they suck on corners.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
summit or jegs, do not get a spool, not a good idea
or you can check out ebay and pick up a second hand posi for a bit less
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I recently bought the Detroit true trac off summit for $375. Hard to find on their website though.
A full $100 cheaper than any other diff basically. Comparable in design to the torsion ones put in 4th gens, but stronger.
Might be worth looking in to.
dbrochard
Sep 19, 2015 08:13 PM
