Flywheel question
Old Nov 15, 2007 | 05:41 PM
YigyYo's Avatar
Flywheel question
Im new to flywheels..
What would perform better? Would a heavier steel flywheel (30lbs) or a lightweight aluminum flywheel (15lbs) perform best?
Would a certain weight perform better for any type of engine? or would it vary..say a stock 305 vs a HO 383.. would light be good for one and not the other, or same?
Thanks.
Old Nov 15, 2007 | 05:51 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Flywheel question
I only run lightweight flywheels on race engines that I'm trying to rev up really, really fast, like a stock car engine.
Whatever flywheel you run, it needs to be balanced to the engine. If you just take yours off and bolt a lightweight piece on, you can kiss your balancing goodbye. You will have weird vibrations just for a start...
I prefer the heavier units because I like durability. Also, with high compression, it helps if you have a heavier piece pulling on the crank to get it over the compression stroke.
Old Nov 15, 2007 | 05:57 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
is a sb chevy interally or externally balanced? i have changed flywheels on them and never had any vibration.
Old Nov 15, 2007 | 06:15 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
sbc are internally balanced. Trust me, it still matters if you drop a light weight flywheel onto your stock engine.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Trickskier
Aug 29, 2015 01:12 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
