tranny linkage questions!!
Old Nov 16, 2007 | 10:20 AM
86irocguy's Avatar
Car: 1986 Iroc-Z
Engine: 350 4-Bolt Main
Transmission: Rebuilt 700R-4
Axle/Gears: 3:42
ok first of all this is the first time i have pulled a tranny out of a camaro. now my question is what is the cable on the passanger side of the tranny that goes to the carb and what does it do? and second how do i properly adjust the shifter linkage on the driver side of the transmission? any help would be greatly appreciated. thanks in advance
Old Nov 16, 2007 | 11:07 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: tranny linkage questions!!
The cable on the pass side is the throttle valve and does go to the carb.
http://www.tvmadeez.com/article/index.php this will tell you what it does and how to adjust it.
Loosen the nut on the stud on the shifter arm that the cable attaches to. Make sure the trans likkage in in park, make sure the shifter is in park then tighten the nut. and you should be done.
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
