can someone help me pick a gear set
Car: 85 camaro z28
Transmission: auto to manaul
hi i got a 85 camaro, and a t56 i will be putting in soon. i want to change the pinion and gears. wats a good choose maybe 3.42 or is that to much 4 the highway?? is this something i should pay someone to do, i can install trans, never messed with gears tho.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: can someone help me pick a gear set
4.10s are nice for the double overdrive of the T56.
Pay someone to do it, it's cheaper than buying all the tools and doing it yourself, unless you plan on doing gear swaps again in the future.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
With 3.42's and a T56, you'll never get into 6th gear unless you're going 90 MPH. With 3.73's, you'll get into 6th gear around 75-80. With 4.10's you'll get into 6th gear around 65-70. But on the street with 4.10's you'll be in 4th gear and doing 35 MPH.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you have the 94-97 T56, go with 4.10's. 3.42 gears are what come stock on the 94-02 T56 F-body's.
With the 3.42's 6th gear is used only for maintaining your speed (55-70mph) on the highway and has absolutely no pull at all.
hectre13
Aug 26, 2015 08:17 AM
