Converting '89 IROC to 16" Wheel
Old Nov 22, 2007 | 11:49 PM
89IROC5.0TT6s's Avatar
Hello. I have a 1989 IROC that was originally equipped with the very rare 15" IROC wheel. I am planning to convert the car to the 16" IROC wheel. The car also has aluminum drums. According to GM PDI, there are two different front control arms, one for the 15" wheel and the other for a 16" wheel. Has anyone out there ever gone from the 15" to the 16" rims and had to replace the front control arms to accomodate the 16" wheel? Were there any clearance issue with the front tires?
Old Nov 23, 2007 | 07:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Converting '89 IROC to 16" Wheel
No clearance issues.
JamesC
Old Nov 23, 2007 | 10:09 AM
Pat Hall's Avatar
I wondered about that myself when I switched to the 16" wheels on my 89 RS years ago. Physically, there's zero difference in the actual control arms. The only thing GM did different on the cars equipped with 16" wheels from the factory was they put a longer spindle stop on the control arm to keep the wider wheel from rubbing when you turn the wheel all the way to one side. The steering stop is just a piece of metal that's riveted to the front lip of the control arm. Even with the shorter 15" stops, my wheels never rub when turning.
Old Nov 24, 2007 | 06:34 PM
Black Betty's Avatar
Car: '86z28 blacked out/'87 iroc yellow
Engine: '86-305 4bbl, '87-305 tpi
Transmission: '86-tremec tko600, '87-700r
Axle/Gears: '86-3.23, 87-? stock gear
My car came with 14s i had no clearance problems when i put on a set of 16s. Go for it
Old Dec 6, 2007 | 12:21 AM
Thanks for the heads up. Guess I'll have to go that junk yard in Ogden and get a close up.
Old Dec 6, 2007 | 12:08 PM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Well Assuming how other manuafactures put different size rims on their car Im sure the difference between the 15 and 16 is compensated through the tire.
Because ifthey make a car with 3 different size wheels they are gonna run into calibration problems.
So if the car cam with 16s and 17s the 16s would be like a 255/50 tire and the 17 would come in a 275/45 so make up for the overall height of the tire. Unless you are worried about width. But im sure the difference isnt much.
Jay
BlueIroc-Z
Jun 9, 2019 03:22 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
mustangman65_79
Aug 11, 2015 03:17 PM
