1988 IROC need help with the rear end.
Old Nov 25, 2007 | 09:25 PM
travishenry's Avatar
Car: 1988 Z28 Camaro
Engine: TPI 350
Transmission: TH350
Axle/Gears: 3.73 10 bolt
I have a borgwarner rear end and I was wondering if 4.11 ratio will fit. I'm looking for a little better gearing and for any kind of help possible. I'm just starting to bracket race at Sac Drags on wednesday nights. Only upgraded to borg warner rear end. I ran little faster, but still want help and willing to learn new things.
Old Nov 25, 2007 | 10:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 1988 IROC need help with the rear end.
Aftermarket support for the 9 bolt is virtually non-existant. You'd have a hard time finding 4.11 gears.
Old Nov 25, 2007 | 10:14 PM
Engine: TPI 350
Transmission: TH350
o ok well i was thinking about getting the 10 bolt newase. but y is it imppossible to get parts.
Old Nov 25, 2007 | 10:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There aren't enough 9 bolts out there to generate much interest in providing aftermarket parts for them.
Old Nov 25, 2007 | 10:23 PM
Engine: TPI 350
Transmission: TH350
that sucks ill just chang it. What do you think of the 10 bolt. and the gearing i should go with.
Old Nov 25, 2007 | 10:52 PM
83Z28BlackBetty's Avatar
Car: 1983 Z-28, Black w/ Silver Stripes
Engine: LT1 350
Axle/Gears: 3.27 9 bolt posi discs
you can ebay a set of gears for the 9 bolt, they surface every now and then as long as you are vigilant. Also there is a company called Jaws gears that make a set of 3.70 gears for it. Just a little info
~JAKE
PS, i like your hood The crossfire hood is AWESOME! and far too rare!
~JAKE
Last edited by 83Z28BlackBetty; Nov 25, 2007 at 10:52 PM. Reason: Automerged Doublepost
Old Nov 25, 2007 | 11:09 PM
Engine: TPI 350
Transmission: TH350
thanx ill call them monday. My gears are shot need a new set. found the hood in pick n pull for 20 bucks. hella light.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
BlackBoulder
Aug 11, 2015 11:15 PM
