9 bolt rebuild
Old Nov 25, 2007 | 10:44 PM
83Z28BlackBetty's Avatar
Car: 1983 Z-28, Black w/ Silver Stripes
Engine: LT1 350
Axle/Gears: 3.27 9 bolt posi discs
9 bolt rebuild
So i just bought a 9 bolt with 3.45 gears that had munched spider gears. and because there are no replacements easily found i bought a complete 3 series posi carrier off ebay.
Can I just pull the gears off my old carrier and slap em in this one and put it back together? or is there something else I'm missing completely?
Thanks,
~JAKE
Old Nov 27, 2007 | 03:01 PM
TransAM Joe's Avatar
Re: 9 bolt rebuild
Well if it were me I would put all new bearings in, check carrier preload, pinion gear depth, gear pattern wear and then slap it together with a new crush sleeve and set pinion gear backlash. Get a complete setup kit from RATECH and it will include all you need minus the tools. You must know that all carriers are not exactly the same, it only takes a few thousands of an inch to make a difference, do it right the first time.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
