please help, my transmission is not shifting
Old Dec 1, 2007 | 03:03 PM
irocsound's Avatar
The transmission has been rebuilt, I put a manual valve body in it. But i havn't gotten it to shift. It goes into park reverse and nuetral then in 1st it (feels like 2nd) but it doesn't seem to change after that...any hints?
ps. it seems to be semi engaged in neutral. When i rev high enough the car will move forward a little
it has a revers shift pattern also
Does anyone have an idea on what could fix this?
Old Dec 1, 2007 | 06:41 PM
jed5161's Avatar
Car: 88 Trans Am GTA
Engine: 383 Lingenfelter/AFR 670 hp
Transmission: 700r4 3500 stall
Axle/Gears: 3.90 9 inch
Re: please help, my transmission is not shifting
make sure your shifter is adjusted correctly. Take cable of gear selector arm in every gear position and make sure its free. if not look towards shifter/shifter cable issues. May need a multi brand/pattern shifter gear select lever ont he trans. stock/hurst/b&m all use different throws for their shifters
Old Dec 1, 2007 | 10:30 PM
irocsound's Avatar
good point i will check that in the morning. Thank you
i have a b&m ratchet shifter in it.
Old Dec 2, 2007 | 08:14 AM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
make sure you have it filled full with trans fluid
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
