Help installing B&M megashifter
Old Nov 24, 2007 | 04:37 PM
RedLava's Avatar
Car: 86 z28
I bought a used mega shifter that came with the shifter only. I am having a harder time getting it set up than I expected. I have two cables that need to be hooked up and only one place to hook some thing to. I believe to have figured out where one of the cables goes as you can see in my picture.
Another problem is the electrical wires. The electrical piece that connected to the stock shifter has 6 wires, and the one on the mega shifter has only 4 spots to connnect a wire to. Which wires do I hook up and which ones do I leave disconnected?
Thanks for the help
Old Nov 24, 2007 | 04:42 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: Help installing B&M megashifter
you need to get a b&m cable. i'm pretty sure the factory one you have will not work. the other cable is for the steering wheel lock. wire tie it so that it stays all the way in the sleeve.
on the electrical side, the two big wires connect to the neutral safety switch of the shifter and there are 2 wires for the back-up lights(i forget the color) the other two just tape them up(not together) and make sure they don't touch anything else.
Old Nov 24, 2007 | 06:16 PM
RedLava's Avatar
Car: 86 z28
Where would I go about getting the B&M cable?
Old Nov 24, 2007 | 07:01 PM
87zjeff's Avatar
i've seen them at autozone and pep boys. i think oreilly's has them also. or you can get one thru summit and jegs.
Old Nov 28, 2007 | 05:08 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
this may help a little
http://static.summitracing.com/globa.../bmm-80692.pdf
also look on summit for replacement parts and i went with the 3 ft cable for mine even though the send you a 5 ft one.
Old Dec 2, 2007 | 09:45 AM
3ZMan's Avatar
I installed a console megashifter about 5 years ago in my third-gen. What I remember is that the cable was about 5' long. The tricky part was the electricals, I had to buy a relay at Radio Shack and you tied off something to do with the steering wheel lock. The instructions spelled this out pretty clearly.
I just checked on the B&M website and you can download the instructions.
The site is www.bmracing.com. Go to shifters -> street shifters -> console megashifter. There is a link for the installation instructions.
Parts can be ordered from Jegs or Summit - get the specific part numbers from the B&M tech line.
Hope this helps.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
