speedo gears help!
Old Dec 3, 2007 | 04:02 PM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
speedo gears help!
switching from a 2.73 to 3.27? which speedo gears will i need? drive? driven?
i read the tech article and 2.73/3.27 =.834486 which means the gears will be spinning at 83 percent of the original speed, correct? what are the stock drive/driven gears for 2.73? what combo do i need to make my speedo correct?
Old Dec 3, 2007 | 07:18 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: speedo gears help!
17t drive
45t driven
25.7" od of tire
Old Dec 3, 2007 | 07:20 PM
Car: 91 rs
Engine: 305tbi
it that the factory or the new set i'd need for my speedo to be correct?
Old Dec 3, 2007 | 07:21 PM
87zjeff's Avatar
the new set for the 3.27 9 bolt you are wanting to install(i used to have one before i installed the 4th gen rear)
Old Dec 3, 2007 | 07:27 PM
Car: 91 rs
Engine: 305tbi
thanks i just reviewed the tech article and it will be traveling at 82 percent of the indicated speed which is close enough. so 17-45 it will be. thanks again
Old Mar 15, 2009 | 01:10 AM
Car: 91 rs
Engine: 305tbi
sorry to dig this old thread up but i cant seem to make sense of this anymore.
1: what is the factory drive/driven set for a 2.73 rear?
2: what do i need for it to read correctly with the 3.27's i have now?
3: do i need a different driven gear housing?
i cant thank you enough for helping me out since i joined, i feel like such an a** for asking so many questions i just want to get the job done right.
Eric
Old Mar 15, 2009 | 07:26 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
https://www.thirdgen.org/forums/tran...libration.html I don't get how you can be having so much trouble when I just posted this info 2 days ago. It should be made into a sticky.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
