tranny/rear end question
Subscribe
Dec 12, 2007 | 11:10 PM
Alright, so I'll be getting a new engine soon, zz4, rated for 355 hp/405 ft-lb at the crank.
My car is a 6 cylinder right now. I've heard that the transmission was the same for 6 and 8 cylinder engines was the same, just with a different bell housing. Is there any truth to that? If not, will a 700r4 be strong enough?
Also, my rear end is non-LSD/Posi with drum brakes. Can I just buy an LSD rear end off the classified from an 8 cylinder and hook it up? If I get one with disc brakes will I need to change out the cylinders? Will that rear-end even be strong enough?
Thanks a bunch guys.
Reply 0
Dec 13, 2007 | 01:27 PM
Re: tranny/rear end question
The transmission is the same MODEL (700-R4); but it is not THE SAME. The bolt pattern where it bolts to the engine is different, and the 6-cyl is altogether weenier inside (fewer clutches in the clutch packs, etc.) It does not have a "bell housing", the case is one giant piece including that section. So, no, it will not work. You need a V8 one.
Best thing to do for a rear is to get one from a LS1 car (98-02 V8) with a stick shift; it will have disk brakes, posi, and a decent gear (3.42). It will work with your existing hydraulics except that if it comes from a car with 4-channel ABS you will have to re-plumb the brake hydraulic lines because instead of one feed to both wheels like your car has, it will have separate right and left feeds; and some minor creativity will be required for the parking brake.
Reply 0
Dec 13, 2007 | 04:10 PM
Quote: The transmission is the same MODEL (700-R4); but it is not THE SAME. The bolt pattern where it bolts to the engine is different, and the 6-cyl is altogether weenier inside (fewer clutches in the clutch packs, etc.) It does not have a "bell housing", the case is one giant piece including that section. So, no, it will not work. You need a V8 one.
Well, a shop is doing it, so would it be easier to just get a rear end from a 3rd gen camaro? I can have a rear end with say, 2.73 gears right? I will be doing quite a bit of highway driving back and forth to school, probably once a month or so, and 3.42/3.73 would probably kill my mileage even further.
And, will a stock tranny from an 8 cyl be able to handle the engine? If not, I'll just do one of the upgrades for it, but I'd rather know beforehand.
Yea, yea, I know, a shop is doing it. But it's a deal with my parents and they won't let me do it myself.
Reply 0
Dec 13, 2007 | 05:37 PM
Sure.
But then, why bother with all that motor?
Reply 0
Dec 13, 2007 | 08:48 PM
Well, I'm going to have 2 sets of gears. I already have 3.73's from when my car had a 350 ( it was originally a 350 car, but I sold the rear end when that engine died. same for the tranny.)
I was going to just put in the 2.73's for school, and over long breaks, like christmas, spring break, summer, etc, put in higher gears.
I just wanted to make sure that'd be kosher, that it wouldn't chew em up.
Reply 0
Dec 13, 2007 | 09:34 PM
Quote: I was going to just put in the 2.73's for school, and over long breaks, like christmas, spring break, summer, etc, put in higher gears.
Setting up gears for occasions like that would be...well, more work than most people would care to be involved in.
JamesC
Reply 0
Dec 13, 2007 | 10:53 PM
Quote: Setting up gears for occasions like that would be...well, more work than most people would care to be involved in.
JamesC
My breaks are a month long or so. Otherwise, I wouldn't do it.
But thanks for the help, maybe I'll get some lower 3's. Chevy has a 3.14 right?
Reply 0
Dec 14, 2007 | 05:14 AM
Quote: My breaks are a month long or so. Otherwise, I wouldn't do it. But thanks for the help, maybe I'll get some lower 3's. Chevy has a 3.14 right?
Gear set-up would run several hundred dollars a pop, so prepare for wallet thinning. No 3.14's.
JamesC
Reply 0
Dec 14, 2007 | 02:14 PM
Quote: Gear set-up would run several hundred dollars a pop, so prepare for wallet thinning. No 3.14's.
JamesC
Oh, I've got the garage, the tools, and the know-how. I'd be doing it myself. I pretty much do all of my own work, the only reason I'm not doing the swap is because my parents are paying for it as a reward for getting a fat lot of scholarships, and they want a warranty with it.
Reply 0
Subscribe
