85 rearend question?
Old Dec 23, 2007 | 12:28 AM
yamaha_fanatic's Avatar
Car: 1985 Camaro
Transmission: WC T5
i want to buy a limited slip differential for my 85 camaro, i was wondering the specs of my rear end, ring gear size 7.5" or 7 5/8? and how many splines my axles have? It was a 2.8 V-6 Auto. Now with a 350 HO. I know the the ratio is 3.42. Thanks.
Old Dec 23, 2007 | 01:17 AM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: 85 rearend question?
check rpo codes or build sheet
Old Dec 23, 2007 | 07:25 AM
Pat Hall's Avatar
Technically, your ring gear is 7.5", but either size ring gear fits on ALL the carriers. That's why new gear sets are usually listed as 7.5/7.625 under the same part number. An 85 rear has 26 spline axles. They didn't switch to 28 spline until late 89.
Old Dec 23, 2007 | 07:38 AM
Car: 1985 Camaro
Transmission: WC T5
awesome, thanks alot.
Old Dec 26, 2007 | 01:59 AM
czbigboy's Avatar
Car: 85 IROC Z
This is from Powertrax.
http://www.powertrax.com/
Camaro
Rear Axle
1993 - 2000
ZEXEL Z28/Y87
1990 - 2000
GM 7.625" rg 28 10 V6 1931
1987 - 1989
GM 7.75" rg 9 V8 w/o Z87- L/S ONLY
1987 - 1989
GM 7.625" rg 26 10 V6 1932
1985 - 1986
GM 7.625" rg 26 10 All 1932
1982 - 1984
GM 7.5" rg 26 10 4 cyl/V6 1930
1971 - 1981
GM 8.5" rg 28 10 All 1920
1967 - 1970
GM 8.875" rg 30 12 V8 1910
1967 - 1970
GM 8.2" rg 28 10 6 cyl 1940
Hope this helps.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
