quick question
quick question
if i plan on putting a 2200-2500 stall converter in my 700r4, and drive it on the street, i should probably look into an after market tranny cooler, unless i want to cook my tranny, rite?
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: quick question
Right.
Nothing typically wrong with a stall converter except massive extra heat. I'd put a BIG cooler on there, if it was me...
Car: 85 IROC Z
Re: quick question
I got a trans pan that has cooling tubes thru the bottom of it. It also holds 1qt extra fluid. It may not be worth much but I figure every little bit helps.
