bleeding the clutch
Old Dec 25, 2007 | 09:50 PM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Axle/Gears: Uh, Haven't investigated this yet
bleeding the clutch
Whats the trick with this. I tried gravity bleeding it and have had no luck. I didn't have anyone to help me so I haven't been able to try to pressure bleed it. Though, I don't think I will have much luck as I don't see any fluid movement in the resivor(sp) when I pump the clutch. Shouldn't I see fluid shooting out like the brakes? I guess I'm a little confused. Who ever was pulling this car apart knocked the piston out of the actual thing that pushes on the clutch. Luck would have it though, all of the parts were there to put it back together. I just can get it to gravity bleed. Is this a possibility or dosen't it work this way??
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
