Moser 5/8" Wheel Studs
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
Has anyone installed a set of moser 5/8" wheel studs? i need to know the drill bit size and then tap the holes. thanks!
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: Moser 5/8" Wheel Studs
I had my axles done, the M/E axles are so hardened a regular drill bit dulls on the first hole, machinest said even his carbide drill took a hell of a beating. GL
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Axles are very hard metal. When I ordered my new axles, I ordered them predrilled and tapped for 5/8" studs.
My old man drilled from the 1/2 to the 5/8 studs in his 35 spline mark williams axles. - You're gonna need a good tap and a really good bit and some way to dill perfectly square through the flange. A good tap will list what size drill bit to use.
If it's not perfectly square you'll have problems.
New2Chevy
Sep 28, 2015 12:35 AM
84 TA NV
Sep 6, 2015 08:02 PM
