Which rear?
Old Dec 30, 2007 | 06:01 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
Which rear?
OK. I am trying to decide between a stock fully rebuilt 9 bolt or a fully beefed up 10 bolt. I have both already. I just don't know which one to go with. It should cost about the same ether way. The iroc will have enough power to break both. But I need a rear to use before the blower goes on. I'll do a 12 bolt or 9" then. Thanks for all the help in advance! Adam :-)
Old Dec 30, 2007 | 11:42 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: Which rear?
Sounds like you already have your answer!
Why wait till the blower goes on? If you need a rearend why would you waste time money and effort to install a unit you KNOW you're gonna kill?
Just bite the bullit and call Moser.
Old Jan 10, 2008 | 06:34 PM
Re: Which rear?
Well I could. But it doesnt answer my question. And what if I want to put this in my RS afterwards. Adam :-)
Old Jan 10, 2008 | 11:08 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: Which rear?
well depends are you going to fix it or chuck ti when you break it? either way youll have issues to your choice on which you wanna bust up if not both.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
