Rear end swap/mix
Old Dec 31, 2007 | 02:52 AM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Rear end swap/mix
I have two camaros. A parted out 1988 IROC, with the 2.73(?) posi rear end, and a 1991 RS 3.1l v6 with the 3.23 open rear.
Assuming these cars both have factory rears:
Can I pull the ring and pinion from my '91 and fit it to the '87 rear so I can technically have a 3.23 posi?
Will the carriers and housings match in my 91 or do i have to swap the entire thirdmember and what not?
Thanks fellas
Old Dec 31, 2007 | 07:30 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Rear end swap/mix
No. You have two different carriers, 2-series for the Limited slip 2:73 and 3-series for the 3:25 open rear. You can buy a spacer for the 2-series carrier.
Old Dec 31, 2007 | 12:26 PM
draco's Avatar
Engine: 5.0l TBI
I'm looking on summit racing to see which spacer i would need.
I'm not sure which one I need though, is it the ring gear spacer or one of the pinion spacers?
Also is the spline count on the axles going to be the same?
Old Dec 31, 2007 | 12:39 PM
DJP87Z28's Avatar
You are going to need the spacer for the ring gear and other parts required to set up a gear change. The spline count for the axle shafts are different too. 26 for the 1988 and 28 for the 1991. Good luck on this DIY job, you will need it.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
