another 9-bolt Question
Old Jan 1, 2008 | 10:51 PM
85camarojunkie's Avatar
Car: Camaro coupe
I have this 9-bolt i took out of my 89 formula 350 i know it is a 3.27 gear. It had the tag on it. i know its a posi and has rear disc brakes. The yellow painted area on the gear is says 8K679. I have a few pics but what kind of carrrier is it like brand or whatever. sorry the pics are so big. THANKS IN ADVANCE
Attached Thumbnails another 9-bolt Question-104_0491.jpg   another 9-bolt Question-104_0492.jpg   another 9-bolt Question-104_0493.jpg
Old Jan 1, 2008 | 10:52 PM
Car: Camaro coupe
Re: another 9-bolt Question
More Pictures. I drove the car home i dont know if it was the tranny or not but the car had no Get up and go at all. It drove ok, but as long as the car is moving does that mean the rear end works. Im not sure about rear ends. But the fluid was really dirty. Any ideas for checking the rear this. like i said not sure if it was the motor, tranny or rear. Thanks
Attached Thumbnails another 9-bolt Question-104_0494.jpg   another 9-bolt Question-104_0495.jpg
Old Jan 2, 2008 | 12:07 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
There's only one brand of 9-bolt carrier and that's stock GM. Sorry I dont know which aftermarket company they used, but they're long since discontinued. I think the gears were made by Motive, same as the 10-bolts.
Old Jan 2, 2008 | 04:12 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
rear axle gear lube will always be black (discolored) and thick like syrup, unless it's brand spanking new stuff. I don't know at what point it changes color, maybe after it's been up to operating temp for a few thousand miles(?), but on all the rear ends that I've drained, it's always black, thick, and smelly, and that's been on healthy rear ends. unless you've got a magnet and there's particles in there, or frictions are worn smooth, that's the normal state. IMHO.
Old Jan 6, 2008 | 01:24 AM
Car: Camaro coupe
Stupid question then. if something happens can i use any 10 bolt parts like gears and junk like that or not.
Old Jan 6, 2008 | 06:01 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No.
JamesC
MustangBeater20
Oct 29, 2022 09:20 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
