Which Stage for my 700r4?
Old Jan 10, 2008 | 01:50 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Is this a good rebuild kit and will it be able to handle my setup I currently have?
http://www.700r4l60e.com/store/produ...&cat=19&page=1
or do I need to go a stage higher? Detail on mods in my sig.
Old Jan 10, 2008 | 06:24 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Which Stage for my 700r4?
You should be good to go, this is what makes it work:
"Sealed Power Beast sunshell"
Make sure to have your housing checked out. If you've had a failure, you may be in trouble with internal damage. Sometimes it's better to use a junkyard good running pull transmission to shell down and rebuild than one that has already failed.
Good luck!
Old Jan 10, 2008 | 11:45 PM
Pro Built Automatics's Avatar
Unless the transmission is total, use what you have, you know the history of it. And if it is a "virgin" unit, so much the better.
Old Jan 11, 2008 | 09:49 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Naw, my current one lost 3rd and 4th gear. That is why I am rebuilding it stronger. Lost it on the highway doing a WOT run.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
