Auto to Manual tranny swap
Subscribe
Jan 10, 2008 | 09:14 PM
I have a 1991 camaro with a LS1 and as far as i know it only comes automatic tranmission the 700r4
I was wondering if it is possible to do such a swap and if so what would you recommend
Reply 0
Jan 10, 2008 | 09:17 PM
Re: Auto to Manuel tranny swap
search a bit, you will find plenty. Check out the ls1/lt1 section in engine swaps. Are you sure its an ls1? A t56 6 speed came stock behind the ls1. the trans is a 4l60e or something like that, the 700r4 is an older trans, though similar
Reply 0
Jan 10, 2008 | 09:38 PM
yes it is a Ls1 for sure
and i was looking at it today and i am pretty sure that it is a 700r4 tranny
and i have not seen any models like mine with a manuel in it
Reply 0
Jan 10, 2008 | 11:24 PM
You should post up some pictures of the engine so that we can see what you're talking about. The LS1 engine was not invented yet when your car was built so we're all a little confused...
The only thing your car could have had factory was a 3.1 V6, or a 305 or 350 Chevy small block.
Reply 0
Jan 11, 2008 | 11:02 PM
sorry i just got the car
its a 1991 z28 with a 5.7 tpi 350
its also complety stock
Reply 0
Jan 14, 2008 | 12:28 PM
Re: Auto to Manual tranny swap
Well if it's a 350 with TPI then it's a L98 not an LS1 unless the engine was swapped. Yes the 700r4 was the only tranny offered with the L98. Yes you can swap to a manual. A T56 is a good choice. Take a look at the articles in the tech section, there are a few articles covering auto to manual swaps.
https://www.thirdgen.org/technical-articles
Reply 0
Subscribe
