t56 swap question
Old Jan 15, 2008 | 10:10 PM
tpicamarokid85's Avatar
Car: 1985 Z28 (project) drive 2006 F-150
Engine: to be deturmined
Transmission: to be powerglide
Axle/Gears: to be 9".. spool.. possibly 5.14:1
t56 swap question
just read online170 post on the auto to t56 thread... great post but im a lil worried about my future swap, i also want to go t-56 from 700r4... my question is.... i want to use a lt1 t56, clutch, flywheel but will the shifter come through the original spot in the center consol?
Old Jan 15, 2008 | 11:13 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: t56 swap question
Are you thinking of using your automatic shifter plate for the manual transmission? If so, no it wont fit, but you can cut it and make it look real nice.
https://www.thirdgen.org/forums/hist...t=#post3575457
Otherwise, if you convert to a manual console shift plate from a 5 spd car, (which bolts to your console), you will have no problems.
Old Jan 16, 2008 | 09:26 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Yes - After converting from a 700R4 to a T56 I used a factory 5-speed shifter plate from a Third Gen and have no problems.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
