28 inch tall tires what gear ratio
Old Jan 16, 2008 | 05:57 PM
camarokev400's Avatar
I need some help picking out a gear ratio..... My setup:
406 sbc 10.5-1 compression
dart iron eagle 200cc heads
solid roller cam 567 lift, 242 duration
hurricane intake single plane
quick fuel 750 carb
1.5 roller rockers
3800 stall th350 trans
3200 pound car
28x10.5 tires
ford 9 inch rearend
I havent ran this car with this combo yet so i have no idea where to start... desktop dyno says the engine makes 518torque at 4500 and 504hp at 5500 and 497hp at 6000 so i was hoping on crossing the line at around 5500-6000. I have a ford 9 inch rearend with detroit locker 31 spline axles, my guess was a 3.89-4.11. The tires im going to be running will be 28x10.5 drag radials or slicks. If anyone has any experience with a similar setup please help me out so i dont have to buy 2 sets of gears... thanks alot
Old Jan 16, 2008 | 07:22 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: 28 inch tall tires what gear ratio
here`s those two gears in a tci calculator @ 6000 rpm and 8 % converter slip
Attached Thumbnails 28 inch tall tires what gear ratio-3.89jpg.jpg   28 inch tall tires what gear ratio-4.11.jpg
Old Jan 17, 2008 | 09:40 AM
so it looks like a 3.89 will be best then. If the combo actually does run a 11.5 or so.
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
Regal105
Aug 23, 2015 03:45 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
