Diff fluid
Old Jan 19, 2008 | 06:21 AM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Diff fluid
Wanna change my rear end fliud, whats your input on royal purple? also I have the G80 option (limited slip) is there an additive I have to add to the royal purple? some one told me that they needed a special fluid so I dont know if the royal purple will work.
Old Jan 19, 2008 | 07:50 AM
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
Re: Diff fluid
I put royal purple in not too long ago and it had friction modifier in it already , usually if it's got it in there they'll brag about it on the label of the bottle .
Old Jan 19, 2008 | 10:17 AM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Diff fluid
Heard that posi's or limited slips require an additive so wasnt sure if i needed to add it to the royal purple...I knew the RP had a friction modifier in it just wasnt sure if it was the factory suggested.
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
