driveshaft removal
Old Jan 22, 2008 | 12:37 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
driveshaft removal
whats the best way o remove my driveshaft? gotta replace rearsal in tranny is it the two small bolts on he backend of the driveshaft? also do i gotta mark anything for easyinstallation?
Old Jan 22, 2008 | 12:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: driveshaft removal
Unbolt the straps holding the rear U-joint to the pinion yoke, push the shaft forward into the transmission, lower the rear end of the shaft, pull the shaft out.
Old Jan 22, 2008 | 01:46 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Also have a pan or rags by the tranny end because you may loose some fluid. Unless you don't care if it is on the floor.
Old Jun 3, 2008 | 12:56 PM
LoganTA's Avatar
Car: 87 Silver Formula
we have the 4 bolts off the straps on the driveshaft.we cannot get it to move forward into the tranny.
any help?
Old Jun 3, 2008 | 04:02 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Tire iron inbetween the rear yoke and the driveshaft. Pull, get ready to catch the drive shaft.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Stroopwafel
Sep 11, 2015 06:38 AM
Nick McCardle
Sep 10, 2015 08:36 PM
