4th Gen T5
Old Feb 2, 2008 | 01:55 PM
Kevin K's Avatar
Car: 91 rs
Engine: 350 TBI
Transmission: 5 speed manual
4th Gen T5
Hey guys i have a 91 rs covertable with roughly 330 horse can i strap a 4th gen t5 up to this motor to get me by times are hard most everybody understands these times lol
kevin
Old Feb 3, 2008 | 07:03 AM
Pat Hall's Avatar
Re: T-5 Drive/Driven Gear Info--Please Contribute
It's highly unlikely that you'd be able to use a 4th gen T5. They have a funky mounting pattern where they bolt up to the bellhousing, and the input shaft is longer IIRC. You could get by with a 3rd gen, V6 T5. They're far from ideal behind a V8, but they will bolt up in place of your existing trans. The only thing you'd have to buy would be a special clutch disc since the V6 trans has a 14 spline input instead of 26 spline. Someone posted the right disc to do this in the trans forum just about a month ago, so a quick search should turn it up. It has the right spline count, and is the correct diameter (10.4") for a V8 application. The ratios in them aren't that great when used with a V8, but the 3rd gen, V6 T5's are cheap and really easy to come by. If money is that tight, that's probably your best option in the short run.
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
cam-mike
Aug 24, 2015 07:23 AM
