700r4 help
700r4 help
I recently did a 350 carb swap in an 88 305 tpi iroc.....i seem to be missing the plug on the top of the transmission...its a 4 prong plug...do i need this? if so where does the plug go after it leaves the transmission?
Transmission: 4L80E/4L80E
It goes to the ECM. Main function is to lock up the torque converter clutch. Good feature to have operating for the sake of transmission life.
Car: 86 Z-28
Engine: 355 small block XR276HR roller cam
Transmission: TCI built 700r4 2000 lockup stall
Axle/Gears: moser axels auburn posi 3:73 gears
Re: 700r4 help
you mention the lock up in a 700r4 is good for help with the life of the trans. i ask about this because my 91 jimmy with 700r4 has tow package the dealer told me all this does is keeps the tranny from locking up, could you possibly touch on this more.
thanks Jim
thanks Jim
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
