5 Speed Tranny
Old Feb 18, 2008 | 04:14 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
5 Speed Tranny
I found a 5 speed transmission from an 83 z28 in the junkyard that I can get for 500$. Assuming it is still the original tranny, it should be the non-world class right? I know these trannys arent as good as the world class ones but are they still any good? Is this whole set up worth getting for 500$.
Old Feb 20, 2008 | 02:09 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: 5 Speed Tranny
Yeah, its definitely a non-WC, i think the changeover year was 89. $500 for a T5 seems a little steep, but if you can get the pedal (not sure if you need brake pedal too), master/slave cyl, console plate, flywheel, and all other parts for a swap, it's not to bad of a deal.
Old Feb 20, 2008 | 05:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 5 Speed Tranny
Do a search on "z bar" and you may decide that the early models aren't desirable. IIRC, the WC models are 88 up.
JamesC
Old Feb 22, 2008 | 03:32 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: 5 Speed Tranny
If I remember correctly this car had a hydraulic set up in it. Yes i can get the pedals and all.
adelane
Sep 9, 2015 08:51 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
