700R4 won't shift up....
Old Feb 28, 2008 | 06:01 AM
starskyknight's Avatar
I have a 700R4 gearbox attached to my 305 Crossfire.
The box shifts keenly into reverse, drive,overdrive etc. But, it won't go up to 2nd, 3rd....
There is fluid in the box, fresh fluid too.
Is there a cable, pump, electric gizmo that could be causing it or is it time for a new box/rebuild etc?
Old Feb 29, 2008 | 03:38 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Re: 700R4 won't shift up....
is this a suddenly new issue? or is this a new car to you or new tranny install?
Old Feb 29, 2008 | 10:02 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
check the governor gear
Old Mar 2, 2008 | 09:33 PM
billymac49's Avatar
Car: 88 IROC
Engine: 5.0 tpi
Transmission: 700 r4
while you have the gov. out make sure the valve moves freely. with the gear pointed up move press the butterfly weights and realese a couple times. if the valve doesn't move you have a hung valve.
Old Mar 2, 2008 | 09:40 PM
zz_camaro_zz's Avatar
Car: 84 Berlinetta
Engine: 332 CI
Transmission: TH400
Axle/Gears: 3.08
I had that probleam once and it turned out to be my TV cable just needed to be reset. i would try that and see if it helps.
Old Mar 3, 2008 | 02:54 AM
Thanks to everyone who replied. I shall take a looka t some of these things next time I get chance to work on the car.
Steven
Old Mar 5, 2008 | 12:23 AM
zrated57's Avatar
Just had this problem with my transmission. I replaced the governor gear and it fixed the problem.
Hotrodboba400
Dec 10, 2019 07:07 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
