700r4 2nd-3rd slip
Old Feb 28, 2008 | 07:38 PM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
700r4 2nd-3rd slip
A buddy of mine has a 3rd gen camaro with a 5.0 tbi 700r4 It is slipping between 2nd and 3rd under light driving or if you are hard on it. You have to actually take your foot off the gas to get it to shift. Rebuild or possible tv cable out of adjustment? This is a trans out of a wrecking yard after his other trans lost overdrive.
Old Feb 28, 2008 | 07:54 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: 700r4 2nd-3rd slip
when my first transmission was starting to slip, it slipped between 2nd and 3rd. It revved up between 2nd and 3rd....a month later i lost 3rd gear......try adjusting the cable and if it doesnt help...hope your buddy has enuf cash to rebuild it GL
Old Feb 29, 2008 | 12:29 PM
Camaroman575's Avatar
Car: 1988 Chevy Camaro
Engine: 305 V8
ya i went around a turn and punched it and drifted it and after that my car would rev in first all the way to 3500 with very light driving. and when i touch the pedel half way or more it wont shift but just rev all the way till i let off the gas. i lost second and overdrive.. rebuild huh? i also drove my car in overdrive all the time. didn't know you had to have it in drive on the streets and thennn overdrive on the freeway. could that have messed it up also. stock tranny just about 200,000 miles on it and everything else
Old Feb 29, 2008 | 07:05 PM
michael's Avatar
Car: 1991 Formula
Who the heck told you your supposed to drive in low d D on city streets? They are a fool. When its in [D] that is where you should be driving it. Now if you are on steep hills or mountains then yes you are supposed to use low D IE: 3rd gear.
Old Feb 29, 2008 | 09:22 PM
billymac49's Avatar
Car: 88 IROC
Engine: 5.0 tpi
Transmission: 700 r4
the band inside the trans is activated in 2nd gear and 4th gear. this band is known for burning up and possibly causing this slipping between 2nd and 3rd.
Old Feb 29, 2008 | 09:31 PM
michael's Avatar
Car: 1991 Formula
ewwww not what I wanted to hear. I'm going to try the tv cable adjustment from here in the faq section then if that doesn't fix it lucas transmision treatment. I'm affraid to drain the fluid and refill it, because I could drain out anything holding it together as it were. We were always told not to do a trans service on a car that is said to have slipping or shifting problems because it may not drive afterwards. The fluid isn't bad though doesn't really smell burnt and its pretty much still red in color. Maybe just a little off out of the bottle color.
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
