does the tps affect the way a car shifts?
Old Feb 29, 2008 | 08:54 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
Transmission: 700 R4
Hey
I have a 91 Z28. All stock with the 350 TPI. When i got the car the guy said he put a new tpi sensor on it..by himself. Since I have had it, it always idled kind of high(maybe 1200). But anyway the kick down cable for the tranny is adjusted to where its in about as far as it goes. Sometimes at 40-45 mpg range it at a steady pace it will want to buck on me like its trying to bounce between gears, and also when its in overdrive the rpms seem somewhat higher than they should be. So I was wondering if having the Throttle Position sensor not adjusted just perfect would make the car not shift properly. I did back the kickdown cable out once to see what happened, and it shifted very hard just puttin it into drive. so i wasnt sure if the car may be just giving my tranny issues...as in maybe needing rebuilt? i did however change the fluid and filter..so its new.
Old Feb 29, 2008 | 09:18 PM
billymac49's Avatar
Car: 88 IROC
Engine: 5.0 tpi
Transmission: 700 r4
Re: does the tps affect the way a car shifts?
the cable you are talking about is a throttle valve cable (tv cable) and this does affect how early, late, hard, or soft the trans shifts. if not adjusted properly it can have adverse affects on your trans. to properly adjust your cable set the adjustment all the way in. with the car off give it full throttle and the cable should ratchet out. it also sounds like your tps is out of adjustment. this sensor should not affect when your trans. shifts, that is what the govenor is for.
Old Feb 29, 2008 | 09:29 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
adjust the tv cable ,push it in with a screwdriver in right hand ,take left hand push center black piece in as far as it will go ,let off screwdriver so it holds it in place.now take your hand and open throttle to wide open position,you should hear a series of clicks ,center black piece will ratchet out, make sure throttle is in wide open position,take it down the street and see how it changes,later jimmy
Old Feb 29, 2008 | 11:37 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
hey
yeah....i did that a few months ago cause a mechanic told me to try that. But when i put it into drive, the tranny jerked hard....thats why i was thinking maybe it was the tps out of adjustment. i adjusted the tps down today so im gonna check and see if that makes a difference any. may of been to high of an idle when i tried adjusting the tv cable.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
