clutch will not disengage all the way
Car: 87 IROC, 96 Suburban
Engine: 5.0 TPI, Vortec 5.7
Transmission: T5, Built TCI 4L60E
Axle/Gears: 3.45 posi, 3.73 eaton locker
i have replaced the slave cylinder and the master cylinder both. i bled the system very well, the pedal is firm. the only way i get it to fully disengage all the way is if i pump it up 3 or 4 times. then put in into gear. otherwise it wont go into gear. anyone else come across this? it only disengages if i pump it.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: clutch will not disengage all the way
sounds to me like there is still air in it.
