Help setting up the drivetrain to a ford 9"
Old Mar 12, 2008 | 06:28 PM
Bob Brown's Avatar
Car: Red T-Top 89 IROCZ
Engine: 400 / punched out 30
Transmission: 700R4 / 3500 stall
Axle/Gears: Ford 9" 390 gears
I put a ford 9" rear in my 89 IROC but having a time getting it drivetrain to bolt up, can you help?????
Old Mar 12, 2008 | 06:34 PM
Bob Brown's Avatar
Re: I need Help setting up the drivetrain to a ford 9"
[quote=Bob Brown;3675502]I put a ford 9" rear in my 89 IROC but having a time getting the drivetrain to bolt up, can you help????
[quote=Bob Brown;3675509]
Old Mar 12, 2008 | 07:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Help setting up the drivetrain to a ford 9"
What's not bolting up?
What brand diff did you use? Does it have a torque arm mount?
A GM u-joint won't fit in a Ford yoke.
Old Mar 13, 2008 | 06:22 PM
Bob Brown's Avatar
Yes I added a new torque arm spohn, the stock drive shaft can out about 1'' short and I changed the end of the shaft to fit the ford 9"( not very well). I was looking for a yoke that would bolt up to the ford rear and fit the stock drive.
can you help
Old Mar 13, 2008 | 06:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
You can always have a longer driveshaft made.
The 9" comes with a couple of different length yokes. You may need to just find one that's a little bit longer.
As for connecting the GM driveshaft to the Ford yoke, there's a conversion u-joint available. It's going to depend on what u-joint the Ford yoke will use. You're either going to need a 3R/1310 or 3R/1330 conversion u-joint. Both should be available from your local auto parts store. When you find the proper length yoke, take it to your auto parts store and tell them you want a u-joint that fits it on one cross and 3R for the GM driveshaft on the other cross.
Old Mar 13, 2008 | 07:03 PM
Bob Brown's Avatar
I got a conversion U-joint, but the one I got didn't fit inside the yoke, its resting on the tabs in the yoke and the U-bolts don't quite fit. I didn"t know there were different conversion u-joints. Will the drive shaft be ok 1 " short on the Trans ??.
Old Mar 14, 2008 | 12:07 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Proper length for the driveshaft is to push the slip yoke all the way into the back of the transmission then pull it back out 1". The measurement from center to center on the u-joints is the length.
Resting on the tabs. Sounds like your diff yoke is a 1310 and you have a 1330 cross.
Old Mar 14, 2008 | 06:06 AM
Bob Brown's Avatar
Thanks again, I may not be short on the driveshaft, becouse I had to pull it out about 1" to but up to the yoke. The next thing is to set the driveshaft angle witch I have never done. can you tell me how ???
Old Mar 14, 2008 | 08:12 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Instructions should have come with the torque arm
Old Mar 14, 2008 | 05:54 PM
Bob Brown's Avatar
Thay did & I called the people at spohn to put in laymen terms,I understand the terms but I have not been able to get it to come out to -2 degree. Is that were you set yours at??
Thinks the 3R1330 U joint worked out.
colton_carlson
Mar 8, 2019 12:21 PM
usafirebird
Exterior Parts for Sale
Oct 19, 2017 02:00 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
