10 bolt ????????'S
Old Mar 13, 2008 | 11:07 PM
jeepboy180's Avatar
Car: 92' RS 25Th Anniversary
Engine: 305ci TBI
Axle/Gears: 10 bolt limited slip.
10 bolt ????????'S
I want to eventually switch from my 2:73 gears to 3:23 gears. What I was wondering is, if I was to find a decent 10-bolt from a 6-cyl with that ratio, would it be as strong as the one thats in it now???? or would I be better off just getting new gears????
Old Mar 13, 2008 | 11:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 10 bolt ????????'S
Yep, you can just swap rears altogether.
The only difference is drum vs disc brakes, and chances are both are drum so..
Old Mar 14, 2008 | 04:39 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
that v6 rear is not going to be posi though. You're not really going to notice to much of a difference with that small of a gear change maybe 2 tenths in a 1/4 mile.
As far as strength it depends on what year it is from I think in 88 is when they switched to 28 spline axles.
Old Mar 14, 2008 | 09:29 AM
Sonix's Avatar
Car: 1982 Trans-Am
His TBI rear won't be a posi either.
And yea, if it's older it'll be slightly weaker, but again, with TBI he's not in any danger.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
