From bad to worse, please help before I light her on fire
Old Mar 17, 2008 | 07:53 PM
Unholy 89's Avatar
Car: '89 5spd GTA
Engine: 305(LB9) TPI
Axle/Gears: Borg-Warner 3.42
Well, I finally got my new clutch in...started her up today and whine, whine, whine from the tranny. Also eally hard to go in gear. Whinig does not stop with clutch open or closed..just constant. Clutch is also very touchy
I'm maybe thinking throwout bearing?
Any help is greatly appreciated.
I'm getting too old for this shiot
Old Mar 17, 2008 | 08:53 PM
billymac49's Avatar
Car: 88 IROC
Engine: 5.0 tpi
Transmission: 700 r4
Re: From bad to worse, please help before I light her on fire
do you hear the noise when moving or just parked?
Old Mar 18, 2008 | 06:00 AM
Unholy 89's Avatar
Car: '89 5spd GTA
All the time
Old Mar 18, 2008 | 10:32 AM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
What did you replace when you installed the new clutch?
Did you install a whole kit and have the flywheel turned?
Hydraulic or manual linkage?
Old Mar 18, 2008 | 12:41 PM
billymac49's Avatar
Car: 88 IROC
Engine: 5.0 tpi
sounds like poss. throw outbearinig. really only thing moving all the time. does the trans grind going into rev. if so clutch/press. plate issue
Old Mar 18, 2008 | 06:55 PM
Unholy 89's Avatar
Car: '89 5spd GTA
hauled to the shop....had to go out of town and I figured I'd let someone else curse at it. I'll post what they find
92camaroJoe
Jul 29, 2023 07:57 PM
1992Vortec
Aug 31, 2015 08:05 PM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Omega
Aug 10, 2015 12:46 PM
