only 1st and reverse before and after rebuild!!!
Old Mar 23, 2008 | 01:36 AM
welderjordanxv1's Avatar
i have a 1990 3.1 liter v-6 camro. i bought it with a bad tranny got one from pick ur part and tried my hand at rebuilding it. however i was apparently unsucessful at it. the transmission shifts into first and reverse only. anyone have anything i could be missing or just overlooked any advice would be greatly appreciated.
Old Mar 23, 2008 | 07:53 PM
performabuilt's Avatar
Re: only 1st and reverse before and after rebuild!!!
Please describe a little better. Do you mean it goes into the forward gears but will not upshift from first , Or do you mean you have to place in the manual low position to move forward?
Old Mar 24, 2008 | 12:31 AM
If you put the transmission into reverse it engages and drives. If you put the transmission into drive it engages but stays in first gear even if i manually move the gear selector throught the other gears. doesnt act like it wants to shift into any other forward gears at all. had this same problem before rebuilding. Thanks for any input you can provide.
Old Mar 24, 2008 | 12:37 AM
Bad or stuck govenor Or valve body is all you have
Old Mar 24, 2008 | 12:54 AM
well thanks a bunch I really appreciate it. have a good night i will try and look at it after work tomorrow and see what happens.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
