Speedo Driven/Drive Gear Question
Old Mar 28, 2008 | 04:04 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Well ive searched quite a bit and i know i need to replace these two gears after switching to 3.45 gears from the stock ones i previously had. My question is, Does anybody have the part number or links to the right parts i need. I cant seem to find any for the 3.45 gears, the closest i can find is the 3.42 and the 3.73.
Old Mar 28, 2008 | 04:24 PM
Re: Speedo Driven/Drive Gear Question
There's less than 1% difference between 3.42 and 3.45.
You can only change speedo gears in 1-tooth increments.
If you have a T-5, with approximately 20 teeth on the driven gear, that means the "granularity" of your adjustment is about 5%. Totally impossible to make a sub 1% change.
If you have a 700, the driven gear has about 40-some teeth; so the granularity decreases to 2 - 2.5%. Still not possible to make as fine of an adjustment as the 0.8% or so that you are looking for.
Your tires wear by a good ½", from new to old; assuming identical pressures at all times. Likewise, the pressure grows from 32 or whatever, to about 40 or more, at highway speeds; which causes the diameter to grow by about the same ½". That difference in diameter is about 2%, which affects the speedo reading by that amount. Fromo new tires at highway speed pressure, to old tires cold, is ONE WHOLE SPEEDO GEAR TOOTH in a T-5. From one brand of tires to another, could be even more than that.
In other words, the gears for 3.42, are about as close as you're going to get; and even if you got the "perfect" gears for 3.45 (which incidentally were the same ones, from the factory, as for 3.42 cars) , those other factors about the tires, will guarantee that they won't be "perfect" except in a few very limited circumstances.
"Measure with micrometer, mark with chalk, cut with axe"
Old Mar 28, 2008 | 04:31 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
here is a calc. so you can find what gears you need.
http://www.700r4.com/speedoCalc/speedocalc.shtml
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
http://700r4.com/speedoCalc/speedocalc.shtml
Old Mar 28, 2008 | 11:14 PM
beat ya to it lol
Old Mar 29, 2008 | 08:44 AM
krisb410's Avatar
HAHA, Great minds think alike.
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
