Buying and installing stall
Old Mar 30, 2008 | 10:16 AM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Ok i have a 305tbi i was thinking of putting a 2200-2500 stall in it.
So how much would a stall like that cost?
And i heard something about a locking stall should i get one of those?
Then to have a shop install it how much dose it cost?
kevin
Old Mar 30, 2008 | 09:17 PM
25thannivZ28's Avatar
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
Re: Buying and installing stall
I just spent $600 on a brand new stall converter, its a custom built 10" Lock Up style torque converter, 3000-3200 stall. DEFINITELY get lock up, otherwise you'll be running the transmission too hot. There are so many other arguments against NOT getting lock up to even consider otherwise. I had quotes for garages to install mine for $450 plus. Ending result, I did it myself to save the $$. Check out the below website on the lock-up..........
http://700r4.com/faq/faq.shtml
Old Mar 30, 2008 | 09:28 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I got my edge racing 2800 stall for my L98. It was a blast! 9.5" and custom build to your specs, which in my case was bolt on L98.
it cost me about 550 shipped to my door. Good quality stuff. Not sure if the pricing has changed in the last 3-4 years but thats what i paid.
2500 stall would be a blast on that car of yours
Old Mar 30, 2008 | 09:40 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
If you're just looking to get a mild upgrade I would consider an S10 converter out of a 95+ 4.3 s10. They stall at about 2100-2300 behind a V8 IIRC.
So the price should be around 500 to 700 bucks not to bad. But i dont really know how it helps me now will help me in my 0-60 time? Also i am getting my trans worked on alittle where it will chrip the tires in 2nd will also help with stuff like that?
thanks
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
hectre13
Aug 26, 2015 08:17 AM
drathaar907
Aug 6, 2015 04:20 PM
