i am puttimg my th400 tran
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: i am puttimg my th400 tran
https://www.thirdgen.org/forums/tran...arts-list.html
Different tranny crossmember because the TH400 mount is much farther back.
An electric kickdown switch on the throttle somewhere.
A TH400 slip yoke. It has a larger diameter output shaft. You can't use a bolt on yoke found on most pickup trucks with a TH400.
A shorter driveshaft. Nothing is factory available so you need one custom made. Might as well switch over to 1350 u-joints while you're at it.
Some way to move the torque arm off the transmission and onto the tranny crossmember.
Buying an aftermarket torque arm with tranny crossmember solves a few of the problems. Buying a conversion swap kit solves a couple of others. You'll still need the TH400 slip yoke. New factory ones for 1350 u-joints are worth around $100
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
