g80 locking diff on rs? just checking
Old Apr 4, 2008 | 08:31 PM
pyrofire127's Avatar
i just wanted to double check. Im pretty sure that a g80 locking diff would work on my 1990 rs but i just wanted to run it by you guys before i spend the time to swap the rear axle
Oh and if the iroc that i pull the g80 off of has disk brakes will that work with my drums or will i have to upgrade to disk???
oh and how much would a change in gear ratio mess me up?
Last edited by pyrofire127; Apr 4, 2008 at 08:34 PM. Reason: add gear ration question
Old Apr 5, 2008 | 12:51 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: g80 locking diff on rs? just checking
It would be an easier swap if you put the whole IROC rear end in your car to replace the one you have. Do a search and you'll find lots of info on rear end swaps.
Old Apr 5, 2008 | 12:37 PM
oh yes i plan on just switching out the rear ends. which is why i was worried about them having disk brakes when i had drums right now
BRoss99
Aug 10, 2025 05:08 PM
hectre13
Dec 11, 2023 08:14 AM
ydnar417
Sep 23, 2015 05:57 AM
gixxer92
Sep 1, 2015 04:32 PM
knight72
Aug 10, 2015 09:32 PM
