View Poll Results: Gear Ratio? (Read Below First!)
3.23
12.50%
3.42
56.25%
3.55
18.75%
3.73
12.50%
Voters: 16. You may not vote on this poll
Gear Ratio?
Old Apr 7, 2008 | 09:06 PM
90BlackGTA's Avatar
Car: 1990 Trans Am GTA
Axle/Gears: 3.42's
Gear Ratio?
Hey everyone...well it turned out my car had the 9-bolt after all even though the RPO sticker said GU5 for 3.23 (someone must have put a 9-bolt in) ...it looks like I might be getting the 9" Ford Moser as a replacement. Its probably more than I need but is one of the only reasonable options and there are few used 10 bolts around here for my car and price versus a used rusted one and new rear end is comparable. Anyway I was wondering what is the best gear ratio to go with. Here is my car setup and future expectations:
-Car is currently all stock (plan to get it up to 300hp in about a year)
-In the cars lifetime I probably won't go modding it beyond 400hp as its not going to be a drag car or a race car.
-Car has 245/50/16 tires all around if thats important lol
-I still want to have high top end speed but satisfactory gas mileage for city and highway
So heres what gear ratio's I was considering...go with the supposed to be stock 3.23, 3.42, 3.55, and maybe 3.73 (although I hear gas mileage isn't so good) Opinions...Thanks, Josh
Old Apr 7, 2008 | 09:18 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Re: Gear Ratio?
unless the 9 is damaged, IMO keep the 9 bolt and just do a gear change. I have the 3.45 and love it. good gas mileage, great top end, and comes out of the hole.
Old Apr 7, 2008 | 09:19 PM
90BlackGTA's Avatar
Axle/Gears: 3.42's
Re: Gear Ratio?
its really rusted and parts are hard to find...not to mention it failed on me thats why I am doing all this...
Old Apr 7, 2008 | 09:21 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Gear Ratio?
if you can get a 3.42 in the 9 inch get it. else go nearest, which is 3.55
i've run 2.77's 3.27's and 3.42's and i love my 3.42's for my 300hp L98 and stock sized tires. great all around gear.
I still plan to run it for my 500-ish hp 383 although only temporarily till i get some 3.73's or a bigger rear
Old Apr 8, 2008 | 04:35 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: Gear Ratio?
I like the 3.42 gears I have they provide a nice balance between low end performance, but don't get the RPMs up too high on the highway
Old Apr 8, 2008 | 07:37 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Gear Ratio?
3.42 is the best all around gear for a spirited-but-not-quite-racer type car. It is the best compromise between mileage and performance.
You'll be happy with that. 3.5x is the next best thing.
Old Apr 10, 2008 | 10:54 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Gear Ratio?
Stay with the 9 bolt. I am making 470 horse and still have not broken the rear. If you do a gear change with the 9 bolt the only option is 3.7's
Old Apr 11, 2008 | 09:55 AM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Re: Gear Ratio?
I use to have 2.77's in my Camaro, and ran a best of 13.8 at 97. I now have 3.45's and my best is a 13.3 at 100. IMO 3.45 is the best gear for my 300 hp L98, and with 400 lb ft of torque they make for long burnouts as well.
Old Apr 11, 2008 | 02:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Gear Ratio?
i ran 13.89 at 96.6 with my 2.77's as well but on street tires with my converter. Did you have drag radials and/or a converter?
my 3.27's put me at 100mph some times but i was unable to break much better than 13.89 with my street tires. I went 13.88 at 98 with the 3.27's and thats the last of the street tire runs. Slicks went 13.79 in july heat before the rear broke and then went 13.6's with 3.42 10 bolt rear swap in the early winter/late fall
Old Apr 11, 2008 | 03:15 PM
Car: ws6
Engine: ls1
Transmission: m6
Re: Gear Ratio?
13.3 was on DRS yes..
Hotrodboba400
Dec 10, 2019 07:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
