Hydraulic Clutch Rebuild
Old Apr 10, 2008 | 07:55 PM
tb55chevy's Avatar
Does anyone know where to get just the seals to rebuild the Clutch Master Cylinder?
Mine was leaking and the Piston is fine and the cylinder is fine but the seals are just not holding any more.
It is from a 92.
Thanks,
Old Apr 14, 2008 | 10:51 PM
tb55chevy's Avatar
Re: Hydraulic Clutch Rebuild
Well I pulled the Cylinders apart and have some pictures I will post later but I found that my Master was leaking even when It was sitting there and didn't leak any more when the clutch was pressed than not so I pulled it apart further and found an O-ring on the outside of the Cylinder sleave at the top was not sealing very well. I found it by pulling the snap ring and pulling the piston out and blowing air in from the res inlet. catch it in a rag there is a plastic washer and an O-ring. I replaced the O-ring with a 115 (Standard O-ring Harbor freigh $6.99 for an entire kit on sale ) It was a little larger but made sure it sealed. Put it together and so far after a day no leaks.
I will post the piture and more when I find out the seal #'s and whatnot but this may help some from spending $70 and the Parts store for one or $220 at the dealer for the part alone.
devilschariot
Feb 25, 2016 03:08 AM
6998poncho
Sep 25, 2015 02:56 PM
jtwoods4
Sep 3, 2015 05:39 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
