87 IROC 3.27 posi rear end swap
Old Apr 14, 2008 | 07:23 PM
burtuckyboy's Avatar
I am new here and have searched this topic but I have a couple questions about a drum to disc swap. I want to put an 87 posi/disc rear end in my 89 drum brake car. I pulled the posi unit out of a car I parted out. I did not get the emergency brake cables. I removed the only brake line bracket I saw and cut the line there. I did get the proportioning vave. Will the e-brake cables on the 89 work? Did I miss any brackets on the underside of donor car that I will need? If so, where can I purchase the extra items I will need as my donor car is scrapped. Thanks for any info
Old Apr 14, 2008 | 07:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 87 IROC 3.27 posi rear end swap
If you pulled the entire diff assembly, you'll need the park brake cables, brake line, combination valve, probably the master cylinder but I'm not sure if the piston size is different.
Old Apr 14, 2008 | 08:01 PM
midwest's Avatar
There may be a "gotcha" when you go to screw the lines from the car into the proportioning valve. When i did mine, the fitting for the rear brakes ( the big one) was on the bottom instead of one the front. No big deal i was able to un coil the extra coil they put in the line, and bend the line so the fitting mated with the valve. Smooth sailing right? wrong when i went to screw in the two lines for the front brakes, i found that they where the wrong thread. The lines from the car was the typical 10mmx2.0 ISO bubble flare fittings. And the threads on the valve where 10mm x 1.50. bubble
I went to car quest and they make an adapter fitting thats takes the lines form the car and adaptes them to a 11mmx1.50 fitting.
As you can see that this is an unusual thread size, but the pitch is a common metric size. So what i did was chuck the fitting in the lathe. And remove .025" from the threaded portion this in turn equals to .050" total. Then ran a 10mm 1.50 die over the fitting. The fittings turned out awesome. The best part is that you dont need to cut and re flare the lines. If you dont have access to a lathe buy the fittings, then take them to a machine shop and have them cut them for you. Tell them to reduce the diameter of the threaded portion by .050" Then eithe have them thread them with a 10mm x 1.50 die, or you can do that your self.
Old Apr 14, 2008 | 11:32 PM
Thanks for the info. Got any idea about where to purchase the e-brake cables I forgot to grab off donor car?
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
