another is this is a posi (i searched)
Old Apr 14, 2008 | 11:24 PM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
hey guys im lookin to buy a rearend for my 88 iroc. i found one (havent actually seen it yet)
so i need to know if it is a posi , the owner could only tell me it was a 10 bolt disc break from a 85 z28 carburated manual car
so from using the camaro tech data i fugured it was a 3.23 or 3.73 most likely a 3.23.........So did these come in both posi and non posi ?, the owner cant tell me much more about it and the part is about 1.5hrs drive and with todays gas prices i dont wanna drive up there for nothing, any infor would help
thanks
Old Apr 14, 2008 | 11:33 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: another is this is a posi (i searched)
I think you would have to check the RPO card in the car. I believe G80 or G92 are both posi. But I could be wrong about those early cars. Also, you dont know who has had their fingers in it before.
Either way, you are still buying another 26 spline rear end. You might consider upgrading to a 90+ rear end, or a 4th gen rear, with the stronger 28 spline axles.
Old Apr 14, 2008 | 11:37 PM
pearl_iroc's Avatar
Engine: LSX
Transmission: MN12
thanks, i know its risky buyin a 85 rear, but the price is decent, i doubt this guy will wana go and find the rpos (i asked, says he'd get back to me) so i posted the question here, i ve searched for a few months now and would love to get a 4th gen rear, unfortunatly here in Toronto its gonna be about 800-1200 for a complete rear
Old Apr 14, 2008 | 11:40 PM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
G80=Limited slip differential(posi), G92=Performance axle ratio. Don't hold me to that though.
Old Apr 17, 2008 | 11:58 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Have the owner check and see if he can find the axle identification number stamped on the front of the right axle housing. He likely will have to clean off the dirt and rust to find it. The complete number will look like this 2AB 0 103 2. You just need to know the first three numbers/letters
The 1985 codes are....
8JA 3.08 STD
8JB 3.23 STD
8JC 3.42 STD
8JD 3.73 STD
8JP 3.08 POSI
8JQ 3.23 POSI
8KA 3.42 STD
8KB 3.73 STD
8KR 3.08 STD
8PP 3.08 POSI
8PQ 3.23 POSI
8PR 3.43 POSI
8PS 3.73 POSI
Most likely the 8Jx have rear drums and the 8Px have rear disc brakes.
The remainder of the number has to do with who manufactured the axle and when it was made in 1985.
Dave
Old Apr 18, 2008 | 07:35 PM
pearl_iroc's Avatar
Engine: LSX
Transmission: MN12
Thanks a ton for that info man that helped unbelievably,...... I went to see it, and it was not a posi.........so the search contiues lol
Old Apr 21, 2008 | 12:48 AM
Good to hear that you found the information useful, and that you did not spend your $$ on an axle you did not want.
One will turn up, and with the codes, you will know what it left the factory with.
Dave
dbrochard
Jan 28, 2016 08:42 AM
Prodigious
Sep 18, 2015 05:23 AM
manifoldsrme
Sep 17, 2015 11:40 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
