Need help to ID a part on a T56
Car: 1989 Camaro RS
Engine: LT1 from '96 Corvette
Axle/Gears: 3.42 diff
Just swapped a T56 into my third gen. It came with a plug in one of the threaded holes. I attached a picture of a unit that has a sending unit or solenoid or whatever the part is that I need.
can someone please tell me what this part is?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Need help to ID a part on a T56
That is the skip-shift solenoid that makes the trans shift from 1st to 4th gear at low rpms. Only the LT1/LS1 computers have that "feature", so you will not have a problem with it in a thirdgen. Just leave it alone and dont worry about it.
LT1Formula
20
Nov 14, 2015 12:02 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
