speedo and new wheels
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: speedo and new wheels
If your stock tire is a 15" wheel with say, 265/55/R15 and you upgrade to a 17"wheel but don't get a smaller sidewall tire (Making your overall wheel/tire combo larger), then your speedometer will actually read slower than your true speed. This happened on my 67 Camaro when I swapped the original 14" wheels for 15" wheels. At 70mph my speedo read 55....
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, swap the drive or driven gears in the tailshaft. There is a sticky post at the top with links on how to figure out what speedo gears you need based on your tire size.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
