What gears do i have?
Old Apr 30, 2008 | 08:32 PM
TransAm_85's Avatar
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Axle/Gears: Borg warner 3.08's
I have a 1985 Trans am with a 700r4 and a 9 bolt rear end. What gears do I have in my rear? How do i tell what my car has?
Old Apr 30, 2008 | 09:00 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: What gears do i have?
Could be 2.77, 3.27, or 3.45 gears.... hard to say. 3.45 only came in the manual trans cars far as I know, so that only leaves you with the other two **if its all stock and original** anything could have been changed in the last 23 years.... I changed the rear end in mine 3 times in the last 2 years, and the pervious owner did it at least once that I know of too.
Only way to know for sure whats there is to pop off the cover and count the teeth on the ring and pinion gears.
Old Apr 30, 2008 | 09:11 PM
TransAm_85's Avatar
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Do i have to take anything apart besides the cover off. How does counting the teeth tell me what gears i have. how many teeth will they both have
Old Apr 30, 2008 | 09:25 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
next time you drive, do 60 mph and note the rpm in 3rd gear.. it will be easier to tell.. 3.27's will be about 2700rpm.. 2.77's will be down around 2300
Old May 2, 2008 | 04:57 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Just take the cover off and count the teeth.It's the best way to find out.You can also look for the numbers stamped on your gears.
Old May 2, 2008 | 05:26 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
LG4 with atuo a 3:08 9-bolt std or option 3:27.
Old May 2, 2008 | 10:35 PM
Air_Adam's Avatar
I'll give you an example of how counting the teeth works... the gear ratio is the result of some math being done, between the ring gear and pinion gear.
For example - if you count 41 teeth on the ring gear, and 10 on the pinion gear, then 41/10 = 4.10
That would be a 4.10 gear ratio.
41 teeth and 11 teeth would be 41/11 = 3.73 gear ratio
Those are 10 bolt and 12 bolt rear end gear sets I mentioned above, the 9 bolt may use different numbers of teeth, but the math still applies the same.
Thats why you count the gear teeth to figure out the ratio you have. You only have to remove the cover to do it, and its probably due for a rear end oil change anyway, so do that at the same time.
Old May 2, 2008 | 10:57 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
If it's down to 2.77 or 3.27, then raise the rear end of the car, put it in neutral and turn the driveshaft by hand until the wheel(s) go around once. If it's single-trac then leave one wheel touching the ground.
Old May 2, 2008 | 10:59 PM
BigBadJohn's Avatar
Just drop the pumpkin and count them by hand. This way you can change the fluid in the rear end while youre at it
Old May 2, 2008 | 11:03 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Jack up the car.
Put in neutral
mark the drive shaft
mark the tire
turn the tire 10 revolutions by hand
count home many times the drive shaft turns
divide by 10
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
