rear end help
Old May 4, 2008 | 02:24 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
rear end help
hey i have a 9 bolt rear end on my 88 350 trans am gta..... i have the stock 3.23 gears..... i was wondering if i used the 3.70 gears from the slp cars would i benefit over the stock gears..... look at the mods in my sig..... would i benefit any from switching to 3.70 gears.... and which one of these gears would work better... here is a website... i have a probuilt tranny with 2400 stall and a transgo shift kit with a mild cam
http://justdifferentials.com/index.p...ha_filter_id=0
Old May 4, 2008 | 02:39 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: rear end help
Well if you have a 9-bolt rear you have 3:27 gears and not the 10-bolt 3:23, simple mistake. My opinion is why make a gear change if it is not broke. If you have to do it fine, both 3:70's will work. I would go with the Motive gears.
Old May 4, 2008 | 02:42 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: rear end help
Well it depends. What kind of tires do you run, is this a car you drive frequently and what kind of times does it run at the track. Obviously the steeper gears give you a mechanical advantage, but it you already have enough power to completely fry the tires off the line it might not have a very noticable difference
Old May 4, 2008 | 02:49 PM
88fastgta's Avatar
Re: rear end help
i run stock tires its my daily driver car... i get the car close to 12.9 with my mods... my dad told me that 3.70s would wake my car up... and make it faster...... its either a 3.27 or 3.23 im not sure.....
Old May 4, 2008 | 05:41 PM
WIll36's Avatar
Engine: 355, 408
Re: rear end help
If its a 9 bolt then its 3.27 gears. The good thing is that means you have a 3 series carrier as long as thats the gear ratio you actually have. If the car is your daily driver I don't know if that is the best route to go. Yes the ratio change will make the car more responsive, but it will also hurt your fuel economy and you will have more traction issues off the line.
Old May 4, 2008 | 08:14 PM
88fastgta's Avatar
Re: rear end help
is there a rebuilt kit for these 9 bolt cause i would like to rebuild mine.....
Old May 4, 2008 | 09:51 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: rear end help
I have the 3.7's in my car. They launch hard off the line, and for gas mileage, its not to bad. When I am cruising at 70 mph the tach says 2200.
Old May 4, 2008 | 11:35 PM
88fastgta's Avatar
Re: rear end help
hey joe blue.... do you think it would be good for me to switch to 3.70s...... the mods are in my signature... car should run close to 12.9
my mods
Crane 2032 cam, Crane matching springs, Crane AFPR, siamesed Plenum, Ported slp runners, Edelbrock high flow ported intake, slp cold air intake, slp airfoil, flowmasters 3" catback, hedman coated longtubes, Custom 3" y pipe with high flow cat, IAT relocation, Custom burned chip, MSD 6A igintion, accel super coil, Beefed up 700r4 with transgo shift kit, 3.27 rear end, 2400 stall, tranny cooler, smog/air/egr delete...
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
