ppl with stall converters
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
how does lets say a 2500 stall feel like under normal accel.....and under hard accel? thx
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: ppl with stall converters
All converters stall. A stock converter stalls around 1200-1500 rpm.
With a high stall converter, normal acceleration is the same but when the engine rpms are below the stall speed, the converter needs to slip. This slipping creates a lot of heat and a large tranny cooler should be used.
Under hard acceleration, the engine will quickly come up to the stall speed. The purpose of a high stall converter is to put the engine rpms into the powerband where it will do the most work.
Best converter choice is determined by the camshaft's advertised duration. Stall speed should be about 500 rpm above where the cam starts to make power. A camshaft rated at 2000-5500 for example should have a converter with a stall speed around 2500.
Car: 1984 Pontiac Trans Am
Engine: LG4 305 V8
Axle/Gears: 10-bolt LSD
Hotrodboba400
Dec 10, 2019 07:07 PM
MikkoV
Sep 9, 2015 04:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
