rear axle questions
Old May 11, 2008 | 12:28 AM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
rear axle questions
i bought a rear disc, 2.73, limited slip rear axle for my car. it came out of a 86. i have a 1989 rs with 2.73 open diff, drums. my stepfather (also a third gen owner) has a limited slip drum setup out of a 88 IROC he was going to use in his car. he suggested maybe we do a swap. he gets the rear end with the disc brakes limited slip and i get the drum limited slip. im stating to realize that i can swap for discs but its going to be an expensive, complicated pain in the rear. what am i better off doing? would the limited slip drum setup out of a 88 iroc Lb9 be the G92 performance axle ratio? i noted that the 88 was available 2.73's or 3.23's. would the 2.73's be the setup that i have now with discs and the G92 option have drums. it would definitely be cheaper the swap out a drum for a drum setup. how much stopping performance would i gain with a disc swap/ how much acceleration performance would i gain by swaping to
3.23's with a L03. only other mods to the L03 being an open aircleaner and a proper 3" exhaust, performance cat, and shorty headers.
Old May 11, 2008 | 09:23 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Re: rear axle questions
Don't waste your time with the early rear discs, drums work better. I'd go with the drums even if they are the same ratio.
Old May 11, 2008 | 09:39 AM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
does anyone know what the ratio was in a 88 drum limited slip setup from an LB9 car?
Old May 11, 2008 | 02:34 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
you're gonna have to pop that cover off to know for sure.
and I agree with gmgod pre 89 disks are garbage and drums from the same pre 89 era perform the same or better.
Going from 2.73's to 3.23's you won't notice earth shattering acceleration but it will be a slight improvement, and more enjoyable.
Old May 11, 2008 | 04:33 PM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
was the 2.73 rear end from a 88 IROC a rear disc setup like the one i have now?
Old May 12, 2008 | 06:56 AM
squeeezer's Avatar
Car: 5 cars
its the 88 and older discs that suck
89 was first year for pbr aluminum calipers
these were on corvettes and early 4th gens
Old May 12, 2008 | 11:51 AM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
that would be the famous "1LE" rear end, wouldn't it?
Old May 12, 2008 | 05:24 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
ummm yes, that's why I used "pre" 89. In reference to before the 89 PBR brakes.
What would?
Old May 12, 2008 | 11:40 PM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
What would?
i believe the 89 and newer style discs were part of the 1LE package
Old May 13, 2008 | 05:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
So-called 1LE in the case of the rears because all four-wheel disc cars, 89-92, had the PBR's. One reason to chose an 82-88 disc rear end is upgradeabilty, though Ed Miller's "no hasslel" kit may be as good or better for drums:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
customblackbird
Aug 15, 2021 10:16 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
